- February 9, 1999
- Vail, Arizona
- 1992 XLT 4x4
By moving the sensor while it's not connected to the TB you are telling the ECM that you opened the throttle when you didn't.
It is possible you have a bad TPS and it may be giving bad values.. Or not smooth values. With it disconnected you can put your meter on it and measure the impedance. As you rotate the TPS it should smoothly change the impedance. I guess you could do it by measuring the voltage with it connected and the key in the on position (but truck off) and make sure the voltage changes smoothly with no big jumps.
I can't remember if the ECM had to re-learn last time I replaced a TPS or if it got a hold of the idle right away.. I haven't had to replace it often.. I think I'm only on the 3rd on in 400k miles and one I broke when I tried to make it adjustable.
~Mark
~Mark
