o2 sensor wiring harness. how do i remove it? | Ford Explorer Forums - Serious Explorations
damagexinc
Melrose Park, IL
'99 xlt
im trying to change the 02 sensor under my drivers side. (bank 2 sensor 1 i think) and i can't get the damn wiring harness out. any ideas?
Some details might help your quest. If it is a 5.0, I had to remove the console between the drivers/passegers seats. If you lay under the truck you can see the plate that needs to be removed right above the sensor, cut a hole in the carpet, and VIOLA! There it is.
i have the xlt 4.0 SOHC. i might need to do that but i'd rather not. i can see where it goes just not where it ends.
