O2 Sensor | Ford Explorer Forums - Serious Explorations
O2 Sensor
Ncweidner
Houston, TX
97 XLT
I have my CE light on - autozone says that my 1 of my O2 Sensor's are out. I have 4 O2 Sensors 2 in front of the CAT and 2 behind it. My question is which side is Bank 1 and which side is Bank 2?
I have a 97 Ford Explorer XLT - V8
Bank 1 is on the passenger side. I've had idiots at AutoZone swear that the driver's side is Bank 1 but don't believe it. The passenger side is Bank 1.
Chances are good that the O2 sensor is not bad; check everything.
Good luck ....
Before you replace anything, please have the code read again, and post the exact code number --it will be diplayed as a PXXXX
You might have an exhaust leak, which will interfere with the 02 sensor reading.
this is common on your engine, passenger side exhaust manifold cracks first.
Do you have a slight ticking noise on acceleration?
I've got plenty of ticking, and also got, I think, P0402, bank 1, secondary, if I recall. Replaced O2 sensor, and problem was solved. Actually replaced both secondary sensors, as they are harder to get to, and I had to go through the floor, so it was easier to just take care of both while I was in there ... they are cheaper than the primaries.
