O2 sensors not reading.
muddacres
NEW YORK
1998 explorer
98 explorer 4.0 SOHC. Not reading O2 sensors and fuel trim. It runs fine. I replaced computer and tried new O2 sensor. The fuse is fine and it has power at the sensor.:scratch::scratch::scratch: HELP
Jim
SoHK_alumni
Tampa, FL
5.0 V8 2002 Ranger
Any chance the engine temp sensor never reports the engine is up to temp so the ECU stays in closed loop and ignores the O2 sensors?
1996BLKBauer
McHenry, IL
1996 Eddie Bauer AWD V8
It should still show a reading whether it is on closed, or open loop, you might have an issue with a wire somewhere. Possibly not sending anything to the ECU. Back probe the pin on the ECU from the o2 sensor and see what it is reading, it will obviously vary, but see if you are getting anything.
muddacres
NEW YORK
1998 explorer
I pulled the wiring harness out and it checks out fine. While I had it apart I changed the coolant sensor. I took the Explorer back to my buddies shop and the o2 sensors still don't read.:scratch::scratch::scratch:
Jim
