bandana
- April 10, 2012
- '99 Explorer 4.0V6 SOHC
Just flushed the cooling system of my 98 4.0L sohc, and was going to use pink OAT antifreeze - but then read this:
http://www.fcsdchemicalsandlubricants.com/main/quickref/scucEN.pdf
under Usage Notes it says
" All pre-1999 vehicles...... must be serviced with the green-colored engine coolant"
There are plenty of warnings on the net about not mixing different types of antifreeze, but I have flushed thoroughly, so that does not apply.
So... is there some real reason why the new OAT type antifreeze can't be used in the 4.0L sohc, and if so what do you think I should use?
I did find this warning about "classic cars"
http://www.v8register.net/FilesV8WN/Concerns with antifreeze for classic cars 090310.pdf
