OBD 1 code 327 | Ford Explorer Forums - Serious Explorations
OBD 1 code 327
Wanda
Atlanta Georgia
1995 Explorer XLT
I get the trouble code of 327 on my 95 Explorer with a 4.0 I have replaced the EGR Vlave and the DPFE what else can I now do?
The DPFE was replaced because I was getting code 336 last week.
...Can you add your location under your name?
...Have you inspected and cleaned your EGR tube itself?
I will try to add location.
And no I have not cleaned the tube. How would I do this and actually the EGR valve I replaced was not the problem as I first thought it was very clean when i inspected it after repalceing it. This code is a KOEO in case that matters.
Should I inspect the vaccuum lines leading up the the DPFE?
Thank you for that post. I read that post and I'm getting no voltage reading to the dpfe.
...If you post that problem in that thread, Mrshorty should be able to answer your question...;)
