jon_s_brady
- August 17, 2008
- '05 XLT
Many of us on this forum have purchased OBD II Scanners or gone to AutoZone or O'Reilly's to get the codes read. This post is about a tool I've found that I now wouldn't be without.
A group of programmers enthusiastic about Fords have written an application called FORScan. You can find it at www.forscan.org. You can download a copy of FORScan onto your laptop and then purchase an ELM327 device to plug in to your car's OBD II connection. The ELM327 can be found on Amazon for about $10. They can connect to your laptop using WiFi, Bluetooth or good old USB cable. I have one of each and they're all pretty easy to use. If your computer doesn't have in-built Bluetooth you can buy a Bluetooth USB adapter to plug into the USB port on your laptop and away you go. I found a Bluetooth adapter for $3 (it came from China but it works). All up this tool cost me under $20.
But here's why I'm so pleased with it. I bought an OBD II scanner from Harbor Freight a few years ago to try and help diagnosing. It also let me reset the CEL when necessary. The trouble is that it only reads a portion of the total number of DTC codes. What'smore, it wont' read transmission codes. And it doesn't let you read realtime PIDs (Parameter IDs) from the engine. I started looking for a scanner that would let me have a better insight into all these codes and I found one at Walmart.com for more than $200. And they only get more expensive from that point. FORScan does everything these expensive scanners do!
So I encourage everyone to try it - it's only a $20 gamble at worst. Also I'd encourage you to support the programmers by providing your logs and such. They are also looking for beta testers to help develop this tool.
Have fun! us:
Have fun! us:
