OD Button works sometimes... | Ford Explorer - Ford Ranger Forums - Serious Explorations
jeff4912
Seattle, Wa
2003 Ford Explorer 4WD
The OD(overdrive) button on the end of the gear select shifter will sometimes illuminate when pushed and sometimes not.
If I shift to neutral and then back to drive, the OD button and light will usually work then.
Frayed or broken wire in OD harness?
imp
Location
West-Central AZ along the Colorado River
59 Ranchero F250 D'Line
More likely bad switch. They are known to fail. imp
