003XLT
- May 4, 2015
- Ford Escape + Explorer
Hi Everyone,
Thanks for all the great advise you have on here, I've solved several problems on the truck already with your help.
I'm presently stumped on what is causing this one noise. Upon starting the truck there is what sounds like a loose heat sink, PLUS a deeper rumble. I can't quite pin point where it's coming from, but my best guess is near the transmission.
By the time the car is out of the driveway the noise is gone until the next morning. Doesn't happen at stop lights, through warm starts, etc. However every standing-start will rattle whatever heat shield is loose, can't find that either.
There is absolutely no gear slipping, clunking, bad mileage or anything that would otherwise indicate a problem.
In case it helps when I bought the truck it had P0420 and P0430 codes. I reset the codes and ran Lucas fuel system cleaner and cleaned the MAF, throttle plate, and IAC which solved a rough idle and the P0420. The P0430 came back once, the FF data was:
P0430
Fuel System 1 Status
Closed Loop
Fuel System 2 Status
Not Supported
Calculated LOAD Value
57.65 %
Engine Coolant Temp
181.40 °F
Short Term Fuel Trim - Bank 1
0.78 %
Long Term Fuel Trim - Bank 1
-2.34 %
Short Term Fuel Trim - Bank 2
0.00 %
Long Term Fuel Trim - Bank 2
2.34 %
Engine RPM
1,862.75 rpm
Vehicle Speed Sensor
27.34 mph
Ignition Timing Advance #1 Cylinder
34.50 °
Intake Air Temperature
73.40 °F
Air Flow Rate Mass Air Flow Sensor
3.86 lb/min
Absolute Throttle Position
29.41 %
Oxygen Sensor Output Voltage (B1-S1)
0.79 V
Short Term Fuel Trim (B1-S1)
1.56 %
Oxygen Sensor Output Voltage (B1-S2)
0.23 V
Short Term Fuel Trim (B1-S2)
99.22 %
Oxygen Sensor Output Voltage (B2-S1)
0.87 V
Short Term Fuel Trim (B2-S1)
0.00 %
Oxygen Sensor Output Voltage (B2-S2)
0.89 V
Short Term Fuel Trim (B2-S2)
99.22 %
The noise is slowing driving me nuts, any help would be very much appreciated
P0430
Closed Loop
Not Supported
57.65 %
Engine Coolant Temp
181.40 °F
0.78 %
-2.34 %
0.00 %
2.34 %
Engine RPM
1,862.75 rpm
27.34 mph
34.50 °
73.40 °F
3.86 lb/min
29.41 %
0.79 V
1.56 %
0.23 V
99.22 %
0.87 V
0.00 %
0.89 V
99.22 %
