FordGuy2014
- April 22, 2020
- Montreal, QC
- 2014 Interceptor Utility.
UPDATE: As mentioned in one of my replies below, I was finally able to get the car in to get checked and it turns out that there is two different millimeter (mm) size settings for 245/55R18 size tires in one of the modules. It was set to the smaller of the two. So they reprogrammed it to the larger one and voila! My odometer is now matching my GPS from little distances to long distances. We were two vehicles traveling back to the same point and our mileages were like 3 kms off. So problem solved.
Thanks again for all that replied!
Hello.
My 2014 PIU odometer is not reading accurate. My speedometer is dead on comparing it with 2 GPS units.
GPS indicates 850 km driving distance.
OEM Odometer indicates 833 km.
I'm running the OEM wheels and tires (245/55R 18) and the BCMod is set for P245/55R 18 2188 mm.
Now I did notice that the BCMod has 2 settings.
1) 2188 mm 245/55R 18
2) 2208 mm 245/55R 18.
If I try and set the 2208 one I get the P160A code. So I just leave it on the 2188.
Anyone have any Idea how to fix this?
I need it to be right as I charge per KM and my billing is based on the odometer reading.
Hello.
