Odometer reset?
aldive
Elite In Memoriam
1999 XLT
Has anyone had a second generation's odometer reset? Who did/does this? How much?
I would like to get the odometer in my new white face instruments reset from its current 6 miles to my actual mileage.
ExplorerDMB
Moderator/Technician
Moderator Emeritus
Mechanicsville, Virginia
2004 Acura TL
A Ford Dealer can do it - just depends if they will. But, of coarse, they only roll up - not down (which in your case isn't a problem). Other than Ford, I'm not exactly sure how you'd do it. Good luck.
-Drew
Interstate
ABQ, Santa Fe
2002 Sport
I hear some transmission shops will do it too.
aldive
Elite In Memoriam
1999 XLT
96limitedX said:
yes the dealer will do it.
How much? Do they have to pull the cluster or is it done with some electronic magic?
96limitedX
im not really sure...lol but i know when we brought a 91 f-250 cluster into the service department it took a few mins and cost about $30. but that was a few years ago.
davidmmm69
Location
Fall river ma
2010 Ford Explorer V6 Fall River Ma...
2002 Mercury Mountaineer
pretty simple. . i bought one off of ebay cause mine died so i played with the old one and then did the same to the one i bought.
remove the cluster to start with, I have done it both ways from the front and from the rear..
from the front I have done with it still on the vehicle you just have to remove the plastic cover then you take a pointed object. i used an awl and put it between the nubers on the odometer and you can with a little force move them and you can actually hear them click Just do not touch the numbers as the white paint with be altered, and DO not use your fingers cause of the oil will leave marks on everything..
My opinion it is so much easier to do from the back of the odometer...I have added miles removed miles depending on what ever the new odometer said obviously only to make it match what your vehicles true mileage is...
very very simple to do and you will not damage anyrhing
mdriggan
Little Rock, AR
'97 Explorer Expedition
David,
ok I found your write-up about this. Did you take the needles off when you adjusted the odometer from the back? Looks to me it would be easier to do from the front? Anyway, Ill give it another look...
davidmmm69
Location
Fall river ma
i do it from the front.. and no i do not take the needles off..
usually 2 clicks for a nmber to go back or forward one number..
just do not touch it iwth yoyur fingers.. or the grease will be visable..
not really a write up but next time i do it i will definatly take pictures.
since this i think is a topic of much discussion...
Rodeo Joe
Elite Bostonian
Frankin, MA
1997 XLT
David,
Care to help out a fellow Bay Stater? I just installed the Sport cluster in my 97 today, and need to add a 100K miles to it. I figured an experienced person might handle it better than a rookie! :p
Joe
davidmmm69
Location
Fall river ma
why add 100k miles just leave it alone and it makes you feel better lol.
I wish i could do that with the digital readout on my 2002 cause i am at 98000 now..
Rodeo Joe
Elite Bostonian
Frankin, MA
1997 XLT
davidmmm69 said:
why add 100k miles just leave it alone and it makes you feel better lol..
Nah, I'm paranoid! I like to keep it accurate.
Joe
tritt121
Greenbrier, TN
2004 Explorer Sport Trac
Have 04 Sport Trac I need to reset mine to 48000 it's showing 184000. The dealer wants to change whole PCM, any ideas? Great posts on standard odometer.
Similar threads
