OEM 2006-10 touchscreen in a 2005
yeet1331
Location
Florida
Land O Lakes, FL
2005 Explorer Limited
Will the OEM 2006-10 explorer touchscreen fit in a 2005? I don’t want to use an aftermarket radio, and the 2010 Edge/F-150/Super Duty one won’t fit it, I’ve measured.
Join the Elite Explorers for $20. Gets rid of the ads!
94Eddie
2010 Mountaineer Premier
I haven't known of anyone to make this swap. You should check plug compatibility before going too far. IMO, you would be better off going with an aftermarket unit. I have the unit you want to install and while it is nice, you will get more functionality for far less hassle going aftermarket. This way your plugs will already be worked out which might be a major hassle when trying to fit the OEM unit in.
yeet1331
Location
Florida
Land O Lakes, FL
In that case, I have another option in mind.
Check this link out here: 1 Factory Radio 63801994BT: Replacement Radio w/Bluetooth for 2005 Ford Explorer/Mercury Mountaineer | JEGS
94Eddie
Davies0202
Blandon
2002 mountaineer 4.6
Hey, this isn’t really info of it works or not cause honestly no clue but I’ve been in an 2010 Mountaineer with the touchscreen and from my point of view it’s really outdated and not worth the $300 that could get you a decent touchscreen with much more functionality
yeet1331
Location
Florida
Land O Lakes, FL
That would work but you can buy a used one for much less and here is an example. Or you can get something like this.
The one I have works fine, I just found one with a Bluetooth retrofit since I’m trying not to use aftermarket parts, but it doesn’t mean I won’t get an aftermarket screen. Thanks for the help!
94Eddie
You might be able have a local stereo shop make your current radio bluetooth capable for a lot less than $225.
yeet1331
Location
Florida
Land O Lakes, FL
Really? I will look into that!
David May
Mcloud OK.
2005 Explorer 4DR XLT AWD
A 2006 Touch screen radio will not work in a 2005 because the 2006 and later systems are CANBUS systems and the 2005 and earlier are not .. it would be difficult to make that 2006 radio work in a 2005 it can be done but would cost a lot more then a aftermarket radio
boominXplorer
Elite Ranger
Virginia Beach, Va
00 4x4 Mounty
Canbus started in 2004 in the explorers. Now I haven't tried to put one in an explorer but my 07 Focus has a 09 Ford Escape touchscreen in it. It never was an option in the focus but its ALMOST plug and play. It all works except the dimmer function. The touchscreen dimmer is can bus controlled where my focus is old school single illumination wire.
R DIY: 02-05 Explorer Driver's side OEM grab handle install w/pics Modified 2002 - 2005 Explorers 14
J 03 Explorer Limited on OEM Edge Sport 22" wheels Modified 2002 - 2005 Explorers 21
R Anyone know where I could get the OEM radio? Modified 2002 - 2005 Explorers 3
8 OEM ambient lighting install Modified 2002 - 2005 Explorers 16
P i need the oem roof rack Modified 2002 - 2005 Explorers 11
A 17" OEM wheel weight?? Modified 2002 - 2005 Explorers 7
F Why is Darth Vader living in my oem airbox?? and a few other problems Modified 2002 - 2005 Explorers 3
$ Performance calipers for OEM sized rotors? Modified 2002 - 2005 Explorers 11
J 20" and up OEM rims Modified 2002 - 2005 Explorers 2
J OEM plug replacement to HALO Spark Plug Modified 2002 - 2005 Explorers 15
G OEM 3rd Gen Grill/Brush Guard Modified 2002 - 2005 Explorers 17
C Need Tire Advice... How Large Can I Go On OEM Rims? Modified 2002 - 2005 Explorers 2
T KYB vs Monroe vs OEM Shocks/Struts Modified 2002 - 2005 Explorers 21
0 2006 explorer spacer on a 2003 explorer Modified 2002 - 2005 Explorers 2
Number4 2006 stereo fit a 2004? Modified 2002 - 2005 Explorers 2
L To modernize an Explorer 2003 to 2006 Modified 2002 - 2005 Explorers 11
T Will 2006 Mirrors fit an 05? Modified 2002 - 2005 Explorers 3
J Installed 7" Touchscreen - Pioneer AppRadio 2 Modified 2002 - 2005 Explorers 13
