OEM Battery Cable Replacement
klowderm
Christiansburg, Virginia
1998 Ford Explorer XLT
Although I have referred to this site often, this is my first post. I am finding it very difficult to locate and purchase OEM battery cables for my 1998 Explorer XLT 4.0 SOHC (w/o Message Center). The dealer no longer carries the part and I have yet to find an online source to purchase from. The part # is 14300(WC-9450-A) and is also referred by part # F87Z14300HA. Any information would be most helpful as I am experiencing the poorly engineered inner-cable corrosion issue. Thanks in advance!
Join the Elite Explorers for $20 per year. Gets rid of the ads! New $5 per month option.
koda2000
x
do you absolutely need the entire cable, or is it just the terminals that are bad?
klowderm
Since I am not the original owner, I am not sure if the cables have ever been replaced. I would much rather replace the entire cable to eliminate any guesswork with any unseen corrosion. Even a schematic of an existing cable would be good, I could possibly piece together my own.
Freight Peddler
Bloomington, IL
96 Explorer XLT 5.0
I bought my cables at O'reilly a couple months ago. They looked up in the computer what lengths were needed and I got that length cable from their battery cable display wall. Fit just fine.
gsbarry
Houston, TX
Stock 97 4.0 EB SOHC
I just finished replacing my battery cables - that was unnecessarily difficult. I decided to cut away the sheathing on the old cables to inspect the condition of the copper. This is what I found:
This looks like heat damage from the exhaust presumably. The factory setup has a heat insulator midway up - although I noticed only around the positive cable - but not at the bottom near the starter, which is where I found this blackening of the copper on both cables.
Has anyone seen this before? If I'm right, and this is heat damage, it makes me want to find additional heat insulation for the bottom section of cable to prevent recurrence of this issue.
bill06447
Connecticut
1997 Explorer XLT 5.0 AWD
Rock Auto stocks all 3 of them for your truck...
Bill
gsbarry
Houston, TX
bumpity bump bump... to the heat damage question in post #5 above
Steeda04SVT
Kansas City, MO
1997 Eddie Bauer Explorer
So how hard is it to just replace the cable or just even the part that connects to the battery terminal?
gsbarry
Houston, TX
I had to replace the entire cable, which was a major PITA. Replacing the terminal only is easy, but I have seen posts advising people to stay away from the cheap lead terminals.
W FORD OEM battery Stock 1995 - 2001 Explorers 7
A What's OEM p/n for 2000 Mounty front end link assembly? Stock 1995 - 2001 Explorers 0
A Tow Hitch: Aftermarket or Factory OEM? Stock 1995 - 2001 Explorers 5
T P0113 Ford OEM Enhanced KOEO Stock 1995 - 2001 Explorers 1
W OEM reference for rear differential axle seal Stock 1995 - 2001 Explorers 9
A Where can I find Ford OEM part number for front wheel bearing? Stock 1995 - 2001 Explorers 2
E How do you take off the plastic bumper cover/OEM splash guards? Stock 1995 - 2001 Explorers 1
M OEM Shocks for 1997 Eddie Bauer AWD Stock 1995 - 2001 Explorers 2
M Purchasing OEM 4 Door Fender Flares? Stock 1995 - 2001 Explorers 5
A Sealed Power timing chain kits vs Cloyes or OEM Ford quality? Stock 1995 - 2001 Explorers 12
P Installing OEM EB flares on limited Stock 1995 - 2001 Explorers 0
A OEM Fan Alternatives? Stock 1995 - 2001 Explorers 11
4 Bad pcm/ecm/oem relay? Stock 1995 - 2001 Explorers 1
D Oem thermostat bleeder valve Stock 1995 - 2001 Explorers 19
2 How To: 2nd Gen OEM Parking Sensors Stock 1995 - 2001 Explorers 35
A Where to buy it ??? Which oem ? Stock 1995 - 2001 Explorers 6
N 2001 5.0L OEM piston Stock 1995 - 2001 Explorers 5
R OEM Tire Size Replacement Stock 1995 - 2001 Explorers 4
A OEM Reverse Parking Sensor System Retrofit Stock 1995 - 2001 Explorers 1
F OEM flares. Stock 1995 - 2001 Explorers 5
toypaseo OEM rear wiper blade refill insert - Trico 14-2 Stock 1995 - 2001 Explorers 4
6 Head unit won't turn on after cutting OEM amp wires Stock 1995 - 2001 Explorers 2
H OEM Tonneau cover brackets Stock 1995 - 2001 Explorers 0
shadowless127 Where do the OEM fog lights mount to? Stock 1995 - 2001 Explorers 6
intelisevil OEM Remote Starter 2W7Z-19G364-BA Stock 1995 - 2001 Explorers 2
C OEM Floor Mats for 2000 Mercury Mountaineer Stock 1995 - 2001 Explorers 14
toypaseo OEM grill preference? Explorer vs. Mountaineer Stock 1995 - 2001 Explorers 14
S "OEM" replacement fog lights Stock 1995 - 2001 Explorers 2
X OEM rubber Floor mats, do they exist? Stock 1995 - 2001 Explorers 6
S Where to find OEM Torsion Keys Stock 1995 - 2001 Explorers 14
N Even OEM fob won't program! :/ Stock 1995 - 2001 Explorers 3
E Aftermarket OEM look Stereo? Stock 1995 - 2001 Explorers 6
E Going from aftermarket to OEM alloy wheels, need help finding what fits Stock 1995 - 2001 Explorers 3
T adding a oem sub to a mach oem stereo Stock 1995 - 2001 Explorers 0
C OEM interior paint Stock 1995 - 2001 Explorers 1
S source for OEM exhaust Hanger rubber insulators? Stock 1995 - 2001 Explorers 1
M 2000 oem mustangrims Stock 1995 - 2001 Explorers 0
swshawaii OEM "Crumbling" Body Bushing/Mount Mfg. Stock 1995 - 2001 Explorers 1
J Recommendations for Timing Kit (too cheap for OEM) Stock 1995 - 2001 Explorers 11
T OEM vs Ebay timing sets Stock 1995 - 2001 Explorers 13
H Looking for Gray 2nd gen oem floor mats Stock 1995 - 2001 Explorers 15
L Would the small/thin OEM sport flares fit a 4 door? Stock 1995 - 2001 Explorers 1
H OEM cone filter on ranger? Stock 1995 - 2001 Explorers 1
Y 1996 XLT OEM Key Remote Fob: Cannot Program To Match Vehicle Stock 1995 - 2001 Explorers 11
H 2000 oem radio? Stock 1995 - 2001 Explorers 3
S Seeking a 1995 OEM Luggage Rack Stock 1995 - 2001 Explorers 1
H OEM or aftermarket alternator for 2000 Mountaineer V6? Stock 1995 - 2001 Explorers 6
M Intake Gasket -- Use RTV Black ONLY (Omit OEM Gasket)? Stock 1995 - 2001 Explorers 2
K OEM Headlight housings or aftermarket? Stock 1995 - 2001 Explorers 4
R Simple OEM air filter question Stock 1995 - 2001 Explorers 8
Similar threads
