Afrojoe
- June 5, 2016
- Ringgold, GA
- 1998 Ford Explorer XL 4WD
Hello fellow X owners. After some research and a few mind changing finds, I have come to ask a for the knowledge of the elders. My factory clutch driven fan is cracked between blades like almost all of our plastic fans are. My clutch is fine so I can reuse that. But I was looking for non plastic alternatives. I don't want to deal with cracked plastic fans and like the metal fan aesthetic better. However I don't want to purchase an Electric fan because of the high cost and the fact that I'll be doing some offroading. So I was looking at flex fans, but they aren't ideal for low speed high rpm situations and can break at the rivets causing potentially dangerous situations. I also read that they're not good options for water crossings. The only other option I've found is a metal fan from a Gen 2 5.0 explorer but I've read that they create clearance issues in the serpentine and accesories (at least in Gen 1s) which is a danger I'd like to avoid. I have a Gen 2 98 OHV so would the V8 fan have the same clearance issues? Any other metal non-flex fan options out there? Any help is appreciated guys. I'd like to reuse my clutch I'm just having a hard time finding a good fan that I know will fit instead of buying 40 dollars of metal I can't use lol.
