tomrj
- June 22, 2011
- pollock pines, ca
- 97 xlt
hello, I pulled the eng. on girlfreind's 97 explorer xlt( 4.0 SOHC VIN E) and all of the guides are broken as well as the front crank to jackshaft and balance shaft tensioners. Amazingly it still ran good w/ no start up noice, only made noice when it warmed up. My main question is should I use Ebay parts (cloyes 9-0389S, Napa 90398s) and are they comparable to OEM. Also would you use aftermarket water pump, belt tensioner, idle pulley, gaskets, hoses etc or stick w/OEM. the price diff. is huge. thanks for any input Tom
