icecoldbear62
- May 1, 2013
- massachusetts
- 04 Mercury Mountaineer Pr
Looking to buy a set of off road bumpers for my 03 Explorer Sport Trac XLT 4x4 4DR 4.0 want to finally get in it and do some off-roading in it just spent a year and a half getting it ready want it to daily drive and be a capable off roader just did all the brake system that includes master all 4 calipers pads rotors all to shut off the brake lite on dash to shut off replaced the clock spring to get the horn and cruze control working as well as get the airbag lite to turn off replaced the thermostat housing with the new all metal housing new radiator hoses as well as the bypass hose on the water pump to thermostat housing new complete tune-up from the coil pack to new wires to new plugs and not the 200 cheap plugs 12.00 each plugs air filter fuel filters to the pcv then to the inside to replace the power door lock switch on drivers door as well as the power mirror switch new headlight switch as well as the dimmer switch 4 new 6x8 kenwood speakers in the doors still looking for the sub box and factory amp set up that goes on the left side of the truck in the little cabinet behind the rear seat where the jack and the amp sub set up goes !!! NOW ITS JUST TO FIND OUT WHETE I CAN BUY NEW OR USED SET OF OFF ROAD BUMPER DONT MIND USED AS LONG AS YOU HAVE ALL THE ORIGINAL MOUNTING HARDWARE FOR THEM AND THEY ARE IN VERY GOOD SHAPE OR THE NAME OF A COMPANY THAT SELLS THEM !!!!!
THANK YOU FOR YOUR TIME
Darwin Finch
Darwin Finch
