Oh Fudge! | Ford Explorer Forums - Serious Explorations
Oh Fudge!
03_Black_EB
PA
03 Eddie Bauer
I finally got my axle in and everything back together which I should be really happy about. BUT now I noticed that the axle that I pulled out has a washer type thing in the little groove near the end that goes into the transfer case. I don't remember seeing that on the axle that I put in. Do I need to rip this thing apart again and make sure it's on the axle?
been there done that.
sounds like its a circle-clip that keeps the inside CV joint inside the diff. . .you might be able to test it, can you pry the inside joint out with ease or if you can move/push/pull CV joint by hand, humm. .its there for a reason. . .you should be getting good at it, and you have all the tools. Just for a piece of mind i would.
On some other CV Axles i've done, i had to move the clip to the new one.
Yeah, I took it apart and sure enough there was no circlip, and none in the box so I reused the old one. Thanks for the reply!
