Runnin'OnEmpty
- July 20, 2002
- Southeast USA
- 2000 Sport
Hi all. The Sport has a 4.0 OHV with 156K miles. Lately it's had an off-and-on rattle when it's
warm and at low rpm. Also a slight miss or hesitation upon acceleration. It's quiet as a mouse
when it's cold and before the engine oil warms up. The noise is definitely coming from the
front of the engine, behind the radiator, and only at near idle speeds. It will rattle when in gear,
and when shifted into neutral the rattle goes away. (When engine rpm slightly increases.)
My thoughts are that the chain tensioner or guide has broken and allowed slack in the chain
causing the rattle, particularly when the oil is hot and thinner. This might be throwing the cam
timing off and also causing the miss? There are no pending or current codes, and this missing
and noise started at the same time.
I'm familiar with the SOHC tensioner problems, but this is an OHV engine.
Anyone have ideas on this before I start taking it apart? Thanks.
