cabraljf
- July 10, 2008
- Greenwood, Indiana
- '91 Sport
I have a 1991 4x4 Explorer Sport with 152k miles. Currently have Magnaflow exhaust and K&N intake. I have the common lifter noises coming from the engine. I know it will not hurt anything but it is getting annoying and it makes the truck sound like crap.
I have done a lot of searching on many threads the following 2 most helpful:
http://www.rangerpowersports.com/forum/showthread.php?232180-4.0-OHV-power-limits-and-required-parts
http://www.explorerforum.com/forums//showthread.php?t=188502
My plan is to pull the engine out, rebuild, put a SOHC oil pan on it, use 422 cam from Comp Cams, new springs and whatnot. What I am trying to decide on is which would be better/cheaper. Flat top pistons or 95TM heads. From what I can gather both scenarios will get me to ~10:1 compression. I found the heads for $232.80 each at Engine Quest (link doesn't work Part #EQ-CH244B). I found a set of flat piston heads w/ rods at Tom Morana Racing ( http://www.moranav6racing.com/category.html?CategoryID=32 ) for $150.
I plan on taking the engine out of the Explorer anyway so my thinking is that it would be cheaper to get the flat top pistons. As far as I know my heads aren't cracked but they will be checked (for sake of argument I am going to assume that they are good). Are there any reasons why it would be better to choose flat pistons over 95TM heads???
