Afrojoe1449
- October 16, 2015
- Ringgold, Georgia
- 1998 Ford Explorer XL 4WD
How's it going guys. I've started to plan a top end rebuild as I have low compression on cylinder 3. About 60 pounds cold/dry and 70 pounds cold/wet. The rest tested 150-160. I consider having my head worked but one is a 95tm and one is a 98tm on my 98. This lead to me to simplify the process and order heavy duty cast heads from Morana Racing. I was going to get the "stage 2" but the timeline would have been stretched further than I'm comfortable with. To make a long story short. I've ordered new cast heads, the gaskets and bolts to do a head replacement, 12 sealed power lifters, a timing chain set and gaskets, new water pump. This should take care of my compression issue and seal up my coolant leak I believe. But I've been contemplating trying to get a 410 Comp Cam and Smith Pushrods to help improve my X while it's apart. I've read I can use new stock springs, is that still the consensus or will I be breaking components if I don't upgrade springs? Any idea where I can find a 410 Comp Cam? Looks like they're out of stock through major outlets until June. I can swap cams with my heads on correct? Because I might be be able to put the timing chain off until they come in stock. Or I could contact Tom and see if he can custom grind a Cam if he has a core on hand. I'd like to get my X back together in a couple of weeks but also want to do the upgrades on an effective and cost effective way give it's usually my daily driver. Thanks you all for your input and knowledge. Worst case I guess it goes back together stock with better heads, but some performance gained would be great.
