Oil Change Question
blwnsmoke
Staff member
Moderator
Moderator
2020 Explorer ST
I thought the new(er) ford engines had port injection as well as direct injection in order to eliminate (substantially reduce?) coking. If so, is there still a need for catch cans?
The 2nd gen 3.5 Ecoboost does.. The 2.0, 2.3 and 2.7 do not (they aren't 2nd gen). I'm not positive on the 3.0 but my memory tells me it does not.
dstewart51
Lake Hughes, CA
2020 Explorer ST
Callsign
KJ7E
The second generation 2.7L does include the dual injection tech. The 3L is basically the 2.7L with a slightly increased bore and stroke. But like you said, not clear if the 3L includes both port and direct injection.
Even if the 3L has both, a oil separator is not a bad idea.
blwnsmoke
Staff member
Moderator
Moderator
2020 Explorer ST
Thank you for the correction. Just googled it and it went port injection for 2018 but it sounds like just the truck engine. Does the Edge ST and fusion ST have the 2nd gen or only the RWD truck platform.
I've read/heard this version of the 3.0 is new but I dont know what "new" means. With theb2020 parts catalog not out yet on dealer sites, I cant pull parts up on the engine to see.
dstewart51
Lake Hughes, CA
2020 Explorer ST
Callsign
KJ7E
Cant find evidence of Port injection on the 3L, there are some diagrams on parts.ford for the 3L
Injector Assy | FordUS
The 3.0 was first used in 2016 but the 2nd gen 2.7 was first used in 2018. I read the 3L is just a stroked and bored 2.7, so I have to presume its based off the 1st gen 2.7.
geewiz
durango nm
2011Explorer limited
will adding an oil separator affect warranty coverage?
dstewart51
Lake Hughes, CA
2020 Explorer ST
Callsign
KJ7E
Only if by doing so it was shown the separator caused what ever the issue is being claimed. It’s not very likely you would ever have a warranty issue here.
dstewart51
Lake Hughes, CA
2020 Explorer ST
Callsign
KJ7E
Just did my first oil change, used the Amsoil filter and Mobil 1 5w-30, 6qt was about perfect.
Rossi6998
Whittier, CA
2020 Explorer ST
Nice pictures... Thanks!
blwnsmoke
Staff member
Moderator
Moderator
2020 Explorer ST
Love the top mounted filter. Didnt realize it had one.
dstewart51
Lake Hughes, CA
2020 Explorer ST
Callsign
KJ7E
I was worried it would spill oil all down the engine but nope, not a drop.
blwnsmoke
Staff member
Moderator
Moderator
2020 Explorer ST
Nope.. my powerstroke 6.0 was same way.. top mounted, never a drop. Great to see this.
Just ordered MC filter on Amazon for $9.15.
cpainter3
Location
Troy MI
Troy MI
2020 Explorer ST
How easy or difficult was it to control the drainage flow with the giant yellow drain plug? And supposedly it needs to be replaced with each change?
dstewart51
Lake Hughes, CA
2020 Explorer ST
Callsign
KJ7E
I really don’t see why it should be replaced unless damaged. No problem at all to pull the plug and not get hot oil on me.
But, it may not be a bad idea to keep a spare if you do your own oil changes, just in case a tab breaks;
Drain Plug - Ford (KX6Z-6730-B) | TascaParts.com
TonyST
Palm Beach Gardens, FL
2020 Explorer ST
Callsign
KW4WO
I found the Mobil1 M1C-351A filter at Advance Auto ($19.95). I don't mind paying that knowing it is Mobil even though I know the MC part is ok too. Just info for everyone.
blwnsmoke
Staff member
Moderator
Moderator
2020 Explorer ST
Good call, found it for slightly under $9 on amazon with free shipping. Tasca wanted $8.62 for shipping on their $6 part lol.
metroplex
Location
Detroit, MI
Detroit, MI
2018 Ford Explorer XLT
Only the truck 2.7 got split port/direct injection. The 2019 Ford Fusion Sport still has the same 2.7 with the leaky plastic oil pan. Ford switched the truck pans to aluminum (except for the 2.7) to resolve the leaks, I believe on the 3.5 and 5.0 but not the 2.7 for some reason.
The Explorer ST's turbos are very different though and can flow a lot more air. I'm not sure if the ST's 3.0 turbos are the same as the older MKZ 3.0's turbos.
Forddealz
NY
2020 Ford Explorer ST
We can forget all our problems from the last generation explorers. They finally corrected water pump and PTU or whatever it was called.
CDW6212R
Hauls the mail.
Knoxville, TN
98 Limited AWD
The 3.0T was new in the 2017 MKZ, but I don't know if that means it has the port injection also.
BTW, the Amsoil oil filter is about $17 each with their membership pricing, which costs $16 a year as I have been doing. I just bought some more oil for my lawn mowers, I like many of their less obvious products too. Their air filters were very special that they had for OEM applications, but they discontinued that line a while back. I miss those, a filter that you could vacuum, and cleaned at least as well as all others.
Axles of Evil
Louisiana
2020 Platinum
As a word of caution on oil usage....these engines are NOT like the ones we had before. After learning a bit more about the specifications, it is apparently very important to use the correct oil, which is SAE SN-PLUS rated, and should be the DEXOS-Gen-2. It is required to minimize the oil evaporation that travels through the PCV into the intake and coats the inlet valves, additionally and more importantly, it helps eliminate low speed pre-ignition (LSPI). So any old 5W-20 or 5W-30 should not be used that does not meet the SN Plus specification. I will be using the Amsoil Signature 5W-30 in mine once it turns 1,000 miles. No associated with Amsoil in any way, but can vouch for its engine protection capabilities through experience. Thanks /m
metroplex
Location
Detroit, MI
Detroit, MI
We've been using that oil for awhile now on EcoBoost. GM has called for Dexos 1 Gen2 on their GTDI engines for awhile it's not some new spec. Low calcium oils are needed to prevent LSPI. API SP is coming out may 1st 2020 just FYI. The 3.0 EcoBoost is based on the 2.7 EcoBoost, and both engines have been out for years.
M 3.0 oil pan leaks? Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 1
C 3.0 Ecoboost oil check procedure Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 6
N 2.3L oil filter location Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 20
M Factory oil coolers on the ST? Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 0
0 "Oil Life" as reported in Ford Pass does not match vehicle Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 7
H Oil Life Monitor Glitch Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 1
M Burning Oil Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 10
J 2020 ST Oil Spec? Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 10
B Oil Filter Location Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 7
M Explorer ST - oil pan design? Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 15
P Change front grille Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 6
J Did Aviator Lane Keeping just change? Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 4
edwx Tire inflation question. Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 7
J Explorer ST - Towing Capacity question Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 34
M Sport to ST question Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 15
I 2020 Climate Control Question Stock 2020 - 2021 Ford Explorer & Lincoln Aviator 10
Similar threads
