jseabolt
- July 12, 2009
- Kingsport, Tennessee
- 2006 Explorer Limted V8
I went to change the oil on my Explorer today and discovered the oil filter I had purchased would not screw onto my engine.
The last filter I used as an STP S2.
I Googled FRAM TG8A and everything says it will fit a 5 liter engine but the threaded hole is too small. So I compared holes and found the one I removed uses a larger hole.
Went back to the autoparts store and the book says this oil filter fits the 4.0 liter but under 5.0 V8 shows this same filter but there was a subnote of 252 but at the bottom it wasn't listed. And it shows another filter. Apparantly mine uses the other filter.
So I used the PH2 and it fits.
The guy at the store says this filter should fit my 68 Fairlane's 302. He says older Ford small blocks use the smaller hole.
