07EddyB
- November 18, 2011
- Bowling Green, KY
- 2007 Ford Explorer 4.6 V8
Looking forward to the first oil change on the 22 Timberline so I checked out the filter location. The Timberline comes with factory skid plates and there is a hole under the filter in the skid plate - but it seems to be off center of the filter. Wondering if I'm going to have to drop the skid plate to change the oil? It's a vertical filter but they can still release a lot of oil when unscrewed which could result in a mess above the skid plate.
Question is - when you change your oil on the 2.3 how much leakage do you get when you drop the filter? If it's not much then I can just get some rags up there to soak it up - otherwise oil changes just got 8 bolts harder.
