Oil Cooler
Removal
1. Remove the fan shroud. For additional information, refer to «Section 303-03».
2. Drain the engine cooling system. For additional information, refer to «Section 303-03».
µ 3. Remove the oil filter (6731).
4. Disconnect the lower radiator hose from the oil cooler (6A642).
µ 5. Remove the bolt and the O-ring.
µ 6. Remove the oil cooler and the O-ring.
µ 7. Disconnect the oil cooler from the water inlet hose.
8. Clean and inspect the surfaces of the cylinder block (6010) and the oil cooler.
Installation
µ 1. Connect the oil cooler to the water inlet hose.
µ 2. Position the oil cooler O-ring and install the oil cooler.
µ 3. CAUTION:
Be sure to position the O-ring into the groove on the oil cooler. Failure to properly position the O-ring may crush the O-ring and cause an engine oil leak. Coat the O-ring with petroleum jelly to hold the O-ring in place during oil cooler bolt installation.
Install the bolt and O-ring.
µ 4. Tighten the bolt.
5. Connect the lower radiator hose (8286) to the oil cooler.
µ 6. Install the oil bypass filter (6714).
l Coat oil filter gasket with Motorcraft Super Premium 5W-30 Motor Oil XO-5W30-QSP or equivalent meeting Ford specifications WSS-M2C153-G and API Certification Mark.
7. Fill the engine cooling system. For additional information, refer to «Section 303-03».
8. Install the fan shroud. For additional information, refer to «Section 303-03».
µ 9. Start the engine and run for two minutes. Stop the engine and allow the oil to drain back into the pan. Check the oil level and add as required. The oil level should read between the MIN and MAX lines.
l Use clean engine oil meeting Ford specifications WSS-M2C153-G.
Thanks Kevin for reminding me to post this--
I have a picture of the disassembled one-but it will not let me copy--hmmm
