Oil filter question
geojag
Arkansas
2002 Ford Explorer XLT
The short version: My truck does not use a filter that I can find called for on an Explorer of this vintage. It uses a __8a filter, not the __2 filter that pretty much everyone says it should use. I can't figure out why.
A longer version: I bought my 2002 Explorer from an individual who said that he was told the engine was replaced prior to him buying it. It didn't show up on carfax, so I didn't really believe that. It was cheap, and it runs great, so I bought it.
Fast forward to yesterday. Time for an oil change. I went by Walmart and picked up the oil and the filter. The filters listed were all __2, I got the Fram XG2. Well, went to put it on and the threads were way too large. I look at the old filter and it was a __8A. I looked all over and can't find that filter being used for an Explorer of that generation. There is a tag on the engine that has the following information:
2G 966 AA
Made in Cologne Germany
Auto FFV
09/07/01
as well as bal 266 and a barcode.
This would seem to be the original engine since the tag on the door shows the manufacture date as being 09/01.
Any theories on why this engine doesn't use the standard oil filter?
swshawaii
Kailua-Oahu, Hawaii
'05 Sport Trac XLS (RWD)
geojag
Arkansas
Thanks for the information.
I am surprised the engine being replaced didn't show on carfax, but I guess it is an older vehicle so that could have been done before electronic records were as common as they are now, and I guess it could have been done by an independent shop.
It did throw a slight wrench in the oil change, but now I know.
Number4
"I'm counting to 3, then I'm getting your dad."
Woodstock, GA
04 Ford Explorer 4.6l
A clean carfax tells you nothing. A bad carfax tells you what not to buy. Use it only to veryify bad vehicles, knowing that it doesn't tell you if a car is good.
Also, Fram is a 'crappy' filter. Not so much an opinion, but a fact. Just throwing this out there because so many people buy Fram because they see their advertising.
B Oil Filter Question Stock 2002 - 2005 Explorers 7
P Oil & Filter Choice? Stock 2002 - 2005 Explorers 13
D Leak after changing oil filter adapter gasket Stock 2002 - 2005 Explorers 4
D 4.6L V8 Oil Filter Adapter Gasket Stock 2002 - 2005 Explorers 6
D Oil filter adapter gasket Stock 2002 - 2005 Explorers 6
T 2005 Aviator - Oil Filter Adapter Gasket Stock 2002 - 2005 Explorers 6
L size for cap style oil filter wrench Stock 2002 - 2005 Explorers 6
P 2003 Explorer oil filter adapter broke Stock 2002 - 2005 Explorers 3
L slow drip around oil filter 2002 XLT v8 Stock 2002 - 2005 Explorers 5
R 2002 Explorer V6 drips oil on manifold near oil filter Stock 2002 - 2005 Explorers 2
R Replacing transmission pan filter and adding Lucas Oil Transmission Fix Stock 2002 - 2005 Explorers 1
D filter change time vs oil change time? Stock 2002 - 2005 Explorers 2
B Leaking coolant from line connected to oil filter housing - repaired Stock 2002 - 2005 Explorers 1
HiImBrian Oil Filter Adapter Housing Gasket Stock 2002 - 2005 Explorers 37
J V6 Oil Filter Used For a V8 -- Major problem? Stock 2002 - 2005 Explorers 3
N Oil filter spash guard cut wiring harness Stock 2002 - 2005 Explorers 2
J Timing Belt Tensioners or Bad oil filter? Stock 2002 - 2005 Explorers 3
C Oil Filter --very strange Stock 2002 - 2005 Explorers 11
2 Changing the Oil filter housing Gasket: Antifreeze recommendation Stock 2002 - 2005 Explorers 3
2 '02-'05 4.6L owners: Had to replace or have replaced the oil filter adapter? Stock 2002 - 2005 Explorers 8
P Oil leak near filter on 4.6L V8 Stock 2002 - 2005 Explorers 4
M Plastic Pieces on the oil filter, Please Help Stock 2002 - 2005 Explorers 22
Rofocowboy84 Oil Filter Bracket? Stock 2002 - 2005 Explorers 0
O Oil Filter & Startup Noise, Related? Stock 2002 - 2005 Explorers 6
H Lost oil pressure Stock 2002 - 2005 Explorers 2
L Oil gauge and steering Stock 2002 - 2005 Explorers 1
J Oil change scam Stock 2002 - 2005 Explorers 15
S What oil for my 4.0L Stock 2002 - 2005 Explorers 36
F Engine Oil Pressure Sensor Stock 2002 - 2005 Explorers 0
M 2004 Explorer Odometer Flickering and Oil Pressure Gauge not working Stock 2002 - 2005 Explorers 0
K Low Oil Pressure Stock 2002 - 2005 Explorers 3
G Change Oil Soon Stock 2002 - 2005 Explorers 1
M Please help with this noise also smoke and oil Stock 2002 - 2005 Explorers 7
Number4 Oil stop leak Stock 2002 - 2005 Explorers 2
M Dash lights, loss of power steering, no oil pressure Stock 2002 - 2005 Explorers 2
Number4 Save money on oil? Stock 2002 - 2005 Explorers 23
G Oil supply line?? Stock 2002 - 2005 Explorers 0
08EddieCA Oil pump drive assembly- lift straight up? Stock 2002 - 2005 Explorers 3
F Cranks and Won't start? Flooded and Fuel in Oil? 2005 Ford Explorer 4.0? Stock 2002 - 2005 Explorers 7
T Oil pan or transmission aka Uhhh yeah this just happened Stock 2002 - 2005 Explorers 16
H 5R55 oil analysis info from Blackstone labs- Stock 2002 - 2005 Explorers 6
M Gear Oil Stock 2002 - 2005 Explorers 10
H Oil pressure 12PSI at idle (warm) and 24PSI at cruise Stock 2002 - 2005 Explorers 0
H Alternative access point for oil pressure sensor on 4.6 Stock 2002 - 2005 Explorers 0
H Alternative location for oil pressure sensor? Stock 2002 - 2005 Explorers 0
L Nasty Oil Fill Cap Stock 2002 - 2005 Explorers 5
9 High Mileage Oil Stock 2002 - 2005 Explorers 8
C Low oil pressure warning on LCD in aux Stock 2002 - 2005 Explorers 2
L Oil dipstick trouble Stock 2002 - 2005 Explorers 16
K Install oil cooler on stock 03 Explorer Limited Stock 2002 - 2005 Explorers 0
Similar threads
