Oil for tranny and transfer case. | Ford Explorer Forums - Serious Explorations
Uppsala
Explorer, 1999
Hi!
I am about to do some service on my 99' Explorer 4,0L and I have a question regarding the fluids for the automatic transmission and the transfer case.
According to my repair manual the fluid in the transfer case should be "Mercon type tranmission fluid".
In the tranny there must be Mercon V according to what I have read here in the forum.
In the catalogue from my local Ford-part-supplier I read about Motocraft Mercon V. There it is stated that it can be used as replacement for all older Mercon och Dexron III.
Does that mean that I can put Mercon V in my transfer case??
Best regards
Gurra
Uppsala
Sweden
I would say yes you can use Merc V in the TC. It is a semi-synthetic fluid. With Mercon discontinued, you have to upgrade the fluid. I would used Mobil one synthetic AFT. You only need a liter and a half, so it is not expensive, and cheap insurance.
