Oil Found In Air Filter
Andrey888
Location
Ukraine
Odessa
2011 Explorer Lim 302A
When replacing the fan, I found the engine oil from entering the air collector. Engine oil flows into the breather valve of the engine box. Mileage 21000 km. What is this?
Andrey888
Location
Ukraine
Odessa
Engine oil flows to the air vent and air filter.
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
Andrey, what model are you referring to. This is the 2011 and 2012 Ford Explorer forum. The reason I ask is that I'm curious as to why you would be replacing a fan on a vehicle likely still under warranty.
Andrey888
Location
Ukraine
Odessa
5 Explorer (2011) I have no guarantees in Ukraine. Exp we have not sold yet.
Oil is driving into the duct. What is the cause?
VinceL
Frisco, TX
2013 Explorer Limited
I am not sure if the cause is known at this point, but that sounds like what is happening to those who have the burning oil smell during hard acceleration.
If you read the thread I linked, it appears Ford is aware of the problem and is in the process of engineering a fix.
Andrey888
Location
Ukraine
Odessa
peterk9
Staff member
Moderator
Callsign
VE3
Andrey888
Location
Ukraine
Odessa
Here is what it says on www.fordparts.com
Part Name: PCV Valve
Part Number: 6A666 (EV-257)
Part Description: 3.5L V6 Cyclone TIVCT ; Less Electric Heated PCV
Thank you Peter. But exactly what the problem is this valve? Ford is determined?
peterk9
Staff member
Moderator
Callsign
VE3
As far as I know, there is no problem with the PVC valve. Apparently pressure is causing oil to leak into an air filter which then could drop onto the exhaust. There is a lot of discussion on this in the thread; Burnt oil smell during hard acceleration.
Andrey888
Location
Ukraine
Odessa
Thank you Peter. Read it now.
Andrey888
Location
Ukraine
Odessa
Yes, the engine oil dripping on the exhaust manifold, through the holes in the bottom of the air filter box. I do not feel the smell, since I installed a carbon filter cabin
When and where to say about the cause?
12WIExplorerXLT
2012 Ford Explorer XLT
Engine Oil where it shouldn't be -help please-
2012 Explorer XLT with 3.5L V6 engine 19,050 miles: While replacing the air filter, I just discovered pooled oil throughout the length of the rubber intake duct from the intake body (butterfly) nearly right up to the airbox. The engine oil + filter has been changed regularly between every 4,000 to 5,000 miles (not gonna debate about the validity of the: "Oil Life Monitor System" here) and the oil quantity has been meticulously maintained no higher than midway between the min/max level holes on the dipstick. We've never noticed any drop in oil level or any external leakage. No burnt oil fumes/smoke from the exhaust either. As the vehicle is still under warranty, I will be scheduling an appointment ASAP but in the meantime, has anyone else experienced this condition or have any possible causes? This is my first post so, I apologize if this is the wrong location or if this subject exists somewhere else within the forum. I have 2 photos but can't seem to attach them. Any & all help is GREATLY appreciated!
VinceL
Frisco, TX
I recall reading somewhere around here that others have experienced the same issue. I wish I could remember more, but what you describe is familiar.
12WIExplorerXLT
VinceL
Thanks for the comment, similiar occurrences or any other owners with knowledge of this condition is what I'm trying to determine while I'm waiting to get it into the dealership. I just haven't been able to locate this anywhere else.
Thanks
peterk9
Staff member
Moderator
Callsign
VE3
Welcome to the Forum 12WIExplorerXLT.:wavey:
I don't do my own maintenance so I can't say if this oil is normal or not. I wouldn't think so. Perhaps some other member will have an answer.
peterk9
Staff member
Moderator
Callsign
VE3
Don't fret Vince. It happens to most of us as we 'mature'. ;)
CajunFordEx
Cajun Country La
2017 Kia Sorento LX
Callsign
KC5OAO
Not a big deal unless it's lots of oil. My F150 gets oil in the breather if I run it hard. I also have a Kawasaki Vulcan that is notorious for getting oil in the breather.If no smoking or loss of oil in the sump occurs I would not worry about it. Perfectly normal for some motors.
Back in the day we used to have "oil bath" air breathers.
12WIExplorerXLT
Thanks for all the input. The amount of oil throughout the intake duct and at the throttle body did seem excessive to me at the time.
I just dropped it off at the shop and after showing the service rep the pics (I couldn't post for you guys,) he did say he's never: "heard of" or "seen" this issue before. Once I get an explanation/resolution, I'll post further. More to come.....
12WIExplorerXLT
Issue resolved! The problem stemmed from the design of the 2011-2012 valve cover vent tube that connects directly to the air intake tube. This was the first occurrence our dealership has encountered and as such they contacted the Ford Hotline for guidance. Ford advised: replacing the valve cover to incorporate the latest design of the vent tube which now has an internal baffle to prevent oil from migrating all the way up to the air intake tube and to the throttle body. Valve cover was replaced and we'll monitor it regularly from now on.
s_vares
2011 Explorer Limited
Oil in intake and other issues
Hey Guys,
Our 2011 Explorer 3.5 has oil in the intake tube, a good amount.
Found it when I was checking air filter, anyone else have this?
Truck is sitting at dealership as the Active Park assist wont work, they replaced all sensors and a steering rack, still cant figure it out.
Its the 4th trip into the dealer for the park assist, getting old quick lol
1 Oil leak found on the top of the engine? Stock 2011 - 2019 Ford Explorer Discussion 1
G Just got back from Oil Change and found oil on floor Stock 2011 - 2019 Ford Explorer Discussion 26
Bobs2018Explorer How the OEM Oil Cooler works, on a 2018 with the 3.5 V6 Stock 2011 - 2019 Ford Explorer Discussion 3
P Oil leak help!! Stock 2011 - 2019 Ford Explorer Discussion 3
B Loss of power & Low oil pressure light Stock 2011 - 2019 Ford Explorer Discussion 3
R Lab-Chemical Fee Charged for Oil Change Stock 2011 - 2019 Ford Explorer Discussion 11
M Oil vapor smell Stock 2011 - 2019 Ford Explorer Discussion 1
G Low oil pressure light Stock 2011 - 2019 Ford Explorer Discussion 8
E 5w-30 oil in a 3.5 NA Engine Stock 2011 - 2019 Ford Explorer Discussion 6
B Oil leak Stock 2011 - 2019 Ford Explorer Discussion 6
S 3.5L Oil Pressure Sensor Location Stock 2011 - 2019 Ford Explorer Discussion 2
J Explorer 3.5 NA Oil Pan Removal and Install Information Stock 2011 - 2019 Ford Explorer Discussion 1
S 2018 leaking oil Stock 2011 - 2019 Ford Explorer Discussion 3
K 2014 Explorer Oil Leak Stock 2011 - 2019 Ford Explorer Discussion 5
B Proving Oil Changes? Stock 2011 - 2019 Ford Explorer Discussion 41
D 2017 Sport Possible oil leak? Should I be concerned? (pics) Stock 2011 - 2019 Ford Explorer Discussion 10
L 2016 Explorer Platinum - burning oil smell inside the cabin Stock 2011 - 2019 Ford Explorer Discussion 8
J 2018 Explorer Limited 3.5L oil leaks Stock 2011 - 2019 Ford Explorer Discussion 19
Jon M Using oil? Stock 2011 - 2019 Ford Explorer Discussion 7
R Oil Pump failure now have to replace engine Stock 2011 - 2019 Ford Explorer Discussion 22
C Oil leak leads to blown motor without warning Stock 2011 - 2019 Ford Explorer Discussion 45
O Does the 2013 Explorer Sport have a transfer case oil cooler? Stock 2011 - 2019 Ford Explorer Discussion 4
A Rear differential oil leak Stock 2011 - 2019 Ford Explorer Discussion 10
Q Small Oil Leak - Passenger Side Stock 2011 - 2019 Ford Explorer Discussion 10
B Oil leak at start up in extreme cold. Stock 2011 - 2019 Ford Explorer Discussion 10
B oil line Stock 2011 - 2019 Ford Explorer Discussion 0
S ‘14 Explorer stalls in P with Low Engine Oil Pressure Light Stock 2011 - 2019 Ford Explorer Discussion 3
whitemage25 Low Oil Pressure warning at idle Stock 2011 - 2019 Ford Explorer Discussion 27
F 2011 Ford Explorer Low Oil Pressure Light Stock 2011 - 2019 Ford Explorer Discussion 5
E 2017 first PTU oil change and Mod Stock 2011 - 2019 Ford Explorer Discussion 7
C 2018 Explorer XLT Oil Leak Stock 2011 - 2019 Ford Explorer Discussion 11
U Oil change in the wilderness Stock 2011 - 2019 Ford Explorer Discussion 27
D Oil press/Coolant temp/battery status? Stock 2011 - 2019 Ford Explorer Discussion 5
I 2017 Explorer sport, small oil leak, doesn't seem to get fixed. Stock 2011 - 2019 Ford Explorer Discussion 34
P 2013 Explorer oil leak Stock 2011 - 2019 Ford Explorer Discussion 2
N Engine Stall and Oil Pressure Warning While Parking Stock 2011 - 2019 Ford Explorer Discussion 5
O 2016 2.3L oil change too much oil? Stock 2011 - 2019 Ford Explorer Discussion 18
R First oil change for my explorer Stock 2011 - 2019 Ford Explorer Discussion 8
Eltee Resetting Oil Change Interval? Stock 2011 - 2019 Ford Explorer Discussion 7
Exit32 Factory oil filter dissection Stock 2011 - 2019 Ford Explorer Discussion 5
S motor oil debate. Stock 2011 - 2019 Ford Explorer Discussion 50
L 3.5L EcoBoost Turbo Oil Leak Stock 2011 - 2019 Ford Explorer Discussion 13
H Rear Differential Oil Leak? - 2013 XLT 4WD 3.5L Stock 2011 - 2019 Ford Explorer Discussion 16
S Front differential oil leak Stock 2011 - 2019 Ford Explorer Discussion 0
C 2011 explorer oil problem Stock 2011 - 2019 Ford Explorer Discussion 19
B Front Engine Cover Oil Leak on Explorer Sport Stock 2011 - 2019 Ford Explorer Discussion 10
G 2016 Explorer Sport Jerking/Stall Cabin oil smell Stock 2011 - 2019 Ford Explorer Discussion 2
L Oil Leak Stock 2011 - 2019 Ford Explorer Discussion 5
rok8man 2017 Ford Explorer Massive Oil Leak Stock 2011 - 2019 Ford Explorer Discussion 2
S 2014 Sport oil leak? Stock 2011 - 2019 Ford Explorer Discussion 10
Similar threads
