Oil in intake hose!? | Ford Explorer - Ford Ranger Forums - Serious Explorations
Redmanff
Roscoe, IL
92 XLT
I need a little help please from anyone. I have been losing quite a bit of oil and my explorer has been idling rough lately. I noticed today that I had a lot of oil in my intake hose from the maf sensor all the way in to the intake. I dont know where this could be coming from--the only 2 options I can think of are the PCV valve or the hose off the oil filler cap. My oil in the crankcase seems to have a foamy residue lately also? Can anyone help? Thanks
Redman
Iggy flywheel
AZ
94 limited
oil in the hose
I would also check your coolant too to see if there is oil in it. I would do a compression check on the engine. It maybe blowing oil pass the rings or the valve guides. Does the oil have a gray color to it? That would mean coolant is getting into the oil = blowin headgasket. Have you noticed poor performance rough idle?
Hope this gives you some help...........
samtheham
Bradenton, Florida
92' XL
I would asume that you have allready checked the oil level and found it to not be overfilled. I had the exact same problem with mine, and too much oil made it out of the pcv valve and cost me a new MAF ( cleaning it with carb cleaner did no good ) I then cleaned all the oil residure out of the air intake and cleaned the MAP sensore since it got some shi* into it too. then a good cleaning of the intake system with some O2 sensor safe cleaner combined with the new MAF cured the problem of on and off rough idle and Check engine light.
