Hunz
- March 31, 2008
- Hendersonville,NC
- 98 XLT SOHC
Hi guys, I have dealt with this problem far too long and I have decided to make another go at this leak. I put a reman engine in my car 40k ago and ever since I put that baby in oil has leaked out the under side of the crank(front of the engine) I first figured maybe the PCV valve was letting too much pressure build up in the crank and that is where the oil decided to come out. Well, a new PCV valve and still the same leak. My next step was a new front main seal. Still no luck, same leak same spot, I also made sure to put rtv in the keyway and plenty of it this time. The reman engine came with all new gaskets and seals which made me think that maybe the housing the front main seal sits in was scored a little allowing oil to seap through. However when I put that new seal in I didn't see any bad gouges or anything so I just said whatever I guess I'll deal with it. Well I'm back at the crossroads again and I have been thinking maybe it is the upper oil pan gasket near the front of the crank. I remember putting some rtv in the the joint part that wraps around crank, but I didn't much if I remember correctly but that was 4 years back.
Do you guys think I am dealing with a gouge in the front seal housing or a small gap in the upper oil pan gasket where I didn't apply enough sealent? I have oil running down the underside of the oil pan from front to back and the smell of burning oil and a dirty engine is really bugging me, Let me know if you guys have any insight
Thanks
Thanks
