CodiBroney
- January 7, 2018
- 2005 Ford Explorer S-Trac
Recently changed the timing chain assembly on my 2005 ford ford explorer sport trac and after putting it together I suspect I have an oil leak coming from the upper oil pan, it leaks out from between the engine and transmission. I believe it's because I forgot to add sealant to the gasket when I put it back together . Is it possible for me to lower the upper Pan with the engine in the truck to add sealant to the gasket?
