- February 18, 2009
- Winnipeg, Manitoba
- 04 Mustang GT
Ok, Im posting here since Im concerned I might be trashing my torque converter.
Some history- I installed new heads, cam, valvetrain...... A week or so later an oil leak started at the rear of the motor. My first thought was that it was the lower intake oil valley.
This weekend (as the leak is getting pretty bad) I pulled apart the lower intake. I could see right away that that isn't the problem.
Oil seems to be originating from the motor/bellhousing area. The way the dripping is happening, the bottom of the bellhousing/motor gasket line dripps oil right across the bottom. Oil drips a bit heavier from the starter.
From being on the highway, the whole back of the truck is oiled up (From the beginning of the bellhousing back). I guess this is great for rust prevention, but still not a good thing.
Oil sending unit? I can't see where it is laying under the truck with a trouble light. Rear main? Seems like a lot of oil for that.
With the oil leaking, Im concerned I'm going to take my starter out, and if the oils coming from rear main, I might be taking out my torque converter.
So now what? I've never had the motor out of the vehicle, and am not a mechanic. I don't even know where to look. All comments appreciated.
