Thanks for the pics. Nice looking engine
The problem is the idiot light below the IP won't go off. The gage on the IP shows good pressure and appears to worki properly, but the "check oil" idiot light stays illuminated. My 16 year old son has been driving my old vehicle--the problem appeared about the time he did an oil change at school auto shop (not sure whether the light came on before or after he changed the oil...it may have been what prompted the oil change). He also took the vehicle out mudding, but I think the light problem pre-dated that episode.
Assuming it is not just a loose connection, how can I test whether it is the switch on the pan before I replace it? Is there any fix for it? I assume I can get it off without taking the pan off. Is that true? Also, I assume I will need to drain the oil to replace the switch on the pan...is that correct?
