Jim Jermain
- February 20, 2006
- Madison, WI
- 00 XLS
I recently replaced the heads on my '00 4.0 OHV due to the infamous crack - leaking coolant. Before I did I noticed the plug for the cylinder I suspected (#3) was difficult to remove and the threads were coated with a hard carbon - oil substance. I've now replaced the heads and my rough idle problem is gone. However I now have a stumble on acceleration at higher speeds. I decided to replace the plugs and wires. I noticed the base and threads of the #3 plug are coated with oil. I don't think it is leaking from the rocker since the gaskets are new. I checked the compression on cylinders 2 & 3 and both are exactly 150 lbs. Is it possible the leaking coolant messed up the rings on the 3rd cylinder. The trunk has 82K miles. If it is bad rings on this one cylinder, does anyone know if it is possible to remove the piston from below without removing the crank or heads?
Thanks,
Jim
Thanks,
Jim
