hotrod_ron
- July 1, 2006
- Tulsa, Oklahoma
- 96 Explorer Sport
Hi All, reading in my Chilton manual about removing the oil pan, says you have to remove engine? Looks like there is plenty of room under there to remove it with no problems. I want to change the pan gasket cause it has developed a small leak. Also want replace timing chain/sprockets water pump. I have a 96 X Sport 4.0L OHV, my real question is about pulling motor to pull timing cover and oil pan. Thanks
