98EdBomber
- January 5, 2011
- Las Vegas, NV
- 98 E.Bauer 4.0(RWD)
162K miles. Bought vehicle with 20K on it and it ran flawlessly until timing chain issues. Religiously changed oil/filters, among other maintenance (O2 sensors, etc). Currently getting 18mpg. Recently did Cam/jackshaft guides and tensioners repair which went fine. No sludge build up. I removed the oil pan and removed broken plastic pieces and the oil pick-up tube as well and made sure there were no fragments left in the pick-up tube before I reinstalled it (Which could cause low oil pressure). Engine is now smoother. Also did 00M12 kit about 10-20K miles ago. Also replaced oil with 5w-30 regular not synthetic (which shouldnt make a difference here)
Only problem now is the dummy oil gauge is dropping to zero at stop lights and at idle when in park when engine is warm. It started doing this about a week before I decided to do the guide repair. It was pure coincidence on the timing of this happening.
Heres my thoughts on a few things:
I am also getting FRONT camshaft chain chatter at idle (although minor), which i initially thought was because the hydraulic tensioner was wore out. With the oil cap removed, I noticed the camshaft guide bounces around (engine running) as if the tensioner isnt putting out enough pressure to keep the chain taught, causing chatter (presumably). Now this could be because of actual low oil pressure or just a worn out tensioner so Ive ordered a new one to make sure. Hasnt arrived yet.
About the oil dummy gauge. I thought it was the oil sending unit so i replaced it at the same time i did the guide repair but problem still exists.
When I rev the engine(warm) the symptoms go away. Quiet chain, gauges normal. Let off gas and back to idle...symptoms return.
Im scared it might be the oil pump or the crank bearings. ALSO I havent hooked up a mechanical oil gauge yet but that was my next step to see what my actual oil pressure is at idle.
What do you guys think? Can anyone help me get this sorted? Thanks!
