brianmc
- November 23, 2009
- Florida
- '94 XLT
Howdy, not long ago everything was working fine and then next thing I know, I look down and my oil pressure gauge is pinging on L. I could hear it over the radio. Frantically, I look for the nearest gas station to pull over and take a look. Upon inspection there were no knocking sounds from the engine, no sounds out of the ordinary at all, no leaks, everything seemed just like it did before I startered it up that day. So I drive home diagnosing it as a questionable gauge, I wasn't far from home either. On idle, the gauge hovers perfectly in the normal range, around 1k it's fine. As the rpms increase the gauge starts to go haywire bouncing back and fourth. Around 2500 rpm the gauge is dancing between just before L and the lower end of the normal range. There's no strange engine noises, nothing out of the ordinary but this damn gauge going nuts. All other gauges are fine.
The gauge seems to act up more as the temperature gets colder also. Had the oil changed not 1500 miles ago and everything checked out. Has anyone had a similar problem?
