CobraSix
- January 7, 2005
- Massachusetts
- 1991 XLT 4x4
I've lost my manual and couldn't find any information from searching here on the forums. 4 years or so ago, I made a post about oil pressure problems. To make a long story a little shorter, here I go:
2001: I noticed my oil pressure gauge dropping at idle speeds. I went for 10w30 to 10w40 to solve the problem.
2005: Problem had gotten progressively worse to the point that I'm using 20w50 year round just to keep oil pressure at RPMs above 1200. I replaced the sending unit which didn't solve the problem. I tested with a mechanical gauge and found that at 2000 RPM I was at 35psi. At idle I would have 0 psi, infact the oil was sucked out of the capillary tube for the gauge.
Present:
Things I've noticed:
1) If the oil is new, the oil pressure drops off at a lower RPM. As the oil ages the pressure drop comes at a higher and higher RPM.
2) When the engine is cold, oil pressure after start up is fine. The pressure doesn't drop off until the engine has warmed up.
3) Hot days make the oil pressure drop off at a higher RPM.
4) There is NO lifter ticking, engine still purrs like a kitten.
5) The engine does not burn any oil.
All of this has been verified with a mechanical gauge. I've put approximately 80k miles on it since the problem first started.
So, it's gotten me wondering...is it just a blockage around the sensor port? The reason I ask is my oil light has NEVER come on (and yes, the light bulb is working). But I wasn't sure if the oil light is based on level or pressure, or both.
The bottom line is I'm at a turning point on my 91. If indeed it's an oil pump problem, then likely my main bearings are toast and the engine isn't long for this world. Of course I've been saying that for awhile. I've only kept the truck under the condition of "I'll keep driving it until the engine explodes". However, currently the truck won't pass inspection and needs about $600 worth of parts if I do the work myself. The transmission is in decent shape, but not great. I know I've lost some compression on the engine. I've found some decent 1994 explorers for the $500-1000 range with a manual transmission (which is what I want anyways) and don't want to sink $600 into my 91 if the engine is on it's way out. I'd rather get a 93 or 94 with 4 wheel ABS and a manual tranny for that amount.
However, if it's possible the engine isn't going to grenade, I may keep the 91 since I know all of it's problems and a known evil is sometimes better then an unknown one.
Thanks.
Present:
Thanks.
