Is the oil gauge on the left side oil temp or oil pressure. It just has an L and H for low and high.
Anyway.. Its easy to convert that gauge 1st gen analog idiot light to an analog gauge. You still won't have numbers but you can at least see the pressures change.
All you do is change the sending unit to the older/bigger style and short out a resistor on the back of the gauge cluster.
thanks, I want an oil temp guage so I was wondering if I could use the stock sensor location. Now i'll just keep that stock pressure guage and add a oil temp guage.
