Afrojoe1449
- October 16, 2015
- Ringgold, Georgia
- 1998 Ford Explorer XL 4WD
Okay so I know the location of the oil pressure switch. My current connection is tight at the nipple at least. When the engine is completely warm and at idle I'll get gauge fluctuation from 0 to Good. At 1k rpm or higher the gauge settles at good. This leads me to believe I have a bad sender and I want to replace it. However I've managed to buy the incompatible version of my sensor 3 times now and I'm hoping to get a definitive part number for my X. I've got a FAE F2002 in right now which is the smaller less leak prone (i would guess based on it not being the large plastic bulb glued on) style. I've got a 1998 OHV 4.0. Built 7/98 which leads me to believe I should be using the large plastic bulb style? Can anyone confirm this? I've been buying the "with light" style because I know my X has the dummy on/off gauge which I assumed is what it meant by with light. I'm just looking to get a for sure part number that will work so I can stop installing and uninstalling to find out they don't work properly. I'm fairly certain my pressure is good as everything sounds normal and it's only after a while that the gauge fluctuates. I just want the gauge and light to stay normal so I don't have that worry on the gauges anymore.
