Oil vapor smell | Ford Explorer - Ford Ranger Forums - Serious Explorations
    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership!
    If you have an existing Elite membership contact me by PM and I will upgrade your account manually.
Oil vapor smell
metroplex
Location
Detroit, MI
Detroit, MI
2018 Ford Explorer XLT
I have noticed that if I drive the Explorer a bit harder (numerous WOT accel / or downshifts), I start to smell PCV oil vapor in the cabin. If you pop your engine oil filler cap after the engine is shut down from a hot drive, that is the smell I detect inside my cabin. It's not very frequent and seems to only occur in certain drive scenarios. I have a CO detector in the car, and the peak it detected was 14 ppm, but it never beeped when I smelled it. I don't see any oil dripping anywhere and the engine compartment doesn't always smell like the oil vapor.
mguy13sport
NH
2013 Explorer Sport
Some things to check:
- Oil in the air filter/air box tubing
- Valve cover gaskets leaking
- Oil leaking onto exhaust/heat shield
Oil must be going some place it shouldn't and you are getting the burn-off smell from the engine bay into the cabin.
