Mellotron
- April 18, 2002
- Dallas, Texas
- Scout owner
Hey William,
Hi, This is Ches, the Amsoil Dealer.
I would not worry about the viscosity unless you get to a 16.
Since you change the full flow filters out more rapidly, I would not change the bypass until 25,000 or once a year. It is designed to hold a significant amount of contaminants and water. Even the BE-90 that is overkill!
Your silicon is very low. Are you running a stock paper air filter? And do you have the petcock vakve on your bypass or did you pull from the dipstick tube?
Since you have increased the sump value of your vehicle your TBN should stay above a 5 no matter what you do. If you ran a synthetic blend or a Group III your Viscosity would be around 8.3 at that mileage (20WT).
Kilroy,
If you had ran a good synthetic in the LTD (transmission and engine) you could expect it to reach well over 300K with the care you have given it. It's a known fact that synthetics reduce fuel usage and downtime enough to save Americans millions of dollars. The most common problems or solutions synthetics provide is lower emissions which reduce problems with EGR and PCV systems which eventually cut down sludge which is the main problem for engine failures.
P.S. At one of our Corvair meetings a new member showed up in a 69 Ford LTD, red with the trim kit, etc. Man, it was the coolest car I have seen in a long time. You don't see those anymore.
After watching Hawaii 5-O I think a 68-72 Ford 4-door sedan (or Merc) will be my next project in Black of course!
Bookem Danno
www.syntheticwarehouse.com
Sponsor
Kilroy,
Bookem Danno
Sponsor
