Ok super Pissed Now!!! | Page 2 | Ford Explorer Forums - Serious Explorations
You can always convert your E shift t case to manual shift with $15 wrth of parts :)
Umm, not exactly... with the 44-05, there was never a manual shift option. Sure you could gut the motor like some of you 13-54 users have, but I'd be reluctant to suggest a guy in Australia be the guinea pig for that one (parts are hard enough to find down there!)
-Joe
UM no actually its quite simple to gut any Ford shift motor and make the T case manually actuated.....I have to date seen 4 different ways of doing this, ionly one way required using the guts of a shift motor, the others were pretty ingenious, the mcneil truck simply uses a piece of cable
I personaly love my pushbutton, but I think in his case it may be easier to do this then try to locate another GEM and hope it works...etc
I can help with a copy of the ford wiring diag. cd if you need it , just get me an address to send it to , it is american so things are a little different but the functions are all the same just placement is a bit off . Hope it helps , before you burn it !!!
