Old Mattress Syndrome | Ford Explorer - Ford Ranger Forums - Serious Explorations
Explorer75
2013 Ford Explorer XLT
My rear springs sound like an Old Mattress, squeak a lot. I´ve tried 3 different kind of lube, it goes away for a day or 2, then comes back. Any ideas???
Rick
Pumpkin Pilot
Staff member
Admin
Wayoutin, Aridzona
'93 XL Pumpkin Edition
Callsign
AB7FH
You could have the spring packs rebuilt with new isolators and bushings.
Turdle
Lowrider
Staff member
Moderator
Humboldt, KS
2000 Mounty
The sound you describe is often emmited by worn ball joints. ( rear IFS components) Coil springs themselves operate totally silent.
Rick
Pumpkin Pilot
Staff member
Admin
Wayoutin, Aridzona
Callsign
AB7FH
I didn't even look to see which forum this thread was in. Good call Jon:thumbsup:
Turdle
Lowrider
Staff member
Moderator
Humboldt, KS
2000 Mounty
The title lured me in, I thought this was going to be a backache thread-:)
Explorer75
Here are the rear suspension components, I believe this explorer doesn´t have rear ball joints, maybe the are called differently?
By the way, I replaced the upper and lower spring insulators about a year and a half ago...
Explorer75
Finally found the culprit, mount bushing (camera like) in the rear upper control arm. 2 Years ago I had to replace some bushings in the rear knuckle, Ford only sells the complete knuckle, so I purchased Moog. The ones in the knuckle are still good but both rear mount bushings (as pictured) were like this. I replaced them with OEM Motorcraft, they cost the same as the Moog. Suspension is quiet now.
