One last question about watts | Ford Explorer Forums
Redlight43
Western Michigan
`93 Splash & `99 sploder
Hey all, if I wire two 350 watt(rms) subs in parallel, do I use a 700 watt amp? or a 350?
yup. but if the two subs are both 4 ohm single voice coil subs the final ohm load will be 2 ohms so remember that for the amp.
Different wiring configurations change the ohm load, so you wanna look at what a particular amp puts out at different loads.. You would still want each sub getting close to 350w tho, so I would say 700w.. It would definitely be a pretty big difference in how they hit compared to an amp 1/2 as powerful.
Thanx guys. I was figuring 700, not was not quite sure.
