MrWizard
- March 9, 2007
- Bay Area, CA
- '94 XLT, '98 XLT
I've been reading a bunch of stuff about improving your gas mileage and
happened across an explanation of why slower is not necessarily better,
gas mileage-wise. You've probably seen the advice that you should be driving
the slowest speed, at which you are still in the highest gear, for best
fuel economy. Typically 45-55 MPH on the highway.
The contrarian theory is, within a gear, your car gets increasingly better gas
mileage the faster you go (until the aerodynamic drag and rolling resistance
factors start becoming dominant). This is because in the lower RPM ranges
(<2500 RPM) the torque is still steadily increasing - faster than the fuel
consumption - until either the wind resistance overtakes any efficiency
improvements, or until the torque curve flattens out. This point is very
likely not at the slowest speed in top gear, but more likely nearer the point
of maximum torque. Unless you are driving a very very un-aerodynamic vehicle.
Which of course makes me think of my Ford Explorer.
So I thought I'd do little gas mileage experiment with my Explorer and see what
kind of mileage I get at various speeds, while controlling every other variable,
as much as possible. I was surprised to see that I get the best gas mileage at
65 MPH, not 55 MPH. I didn't drive any slower than 55 for an extended period
since you get run over (or shot) around here if you're driving too slow.
Has anyone else seen similar results?
Averages over a 20 mile test range, after a 10 mile warmup.
Speed and MPG data logged continuously on my PC and averaged later in EXCEL.
26.59 MPG at 55 MPH
25.04 MPG at 60 MPH
27.97 MPG at 65 MPH <<<
27.50 MPG at 67 MPH
26.68 MPG at 70 MPH
25.20 MPG at 72 MPH
24.64 MPG at 75 MPH
My very ordinary Explorer: 1994, 4x2, Original Eng, Auto Trans, 3.73 rear end.
Mobil 1 Oil. Tires at 33 PSI. 87 octane fuel. No PCM mods.
Replaced: MAF/O2/EGR/PCV/Wheel bearings/Thermostat/Optima battery/Platinium plugs.
Recently cleaned: IAC/PFE/Seafoamed engine to death.
Changes: Removed roof rack crossbars, Airbox mod.
Lifetime gas mileage over 14 years: A very ordinary 17.3 MPG. Hence the desire to figure out, "where the heck
is all the gas going?" I am amazed at how absolutely awful my city mileage is, and how high it is on the highway.
26.59 MPG at 55 MPH
25.04 MPG at 60 MPH
27.50 MPG at 67 MPH
26.68 MPG at 70 MPH
25.20 MPG at 72 MPH
24.64 MPG at 75 MPH
