srvblues00
- November 22, 2001
- Denver, NC
- 94 Sport / 88 Turbo Stang
Just replaced the clutch on my boss's truck because his slave cylinder was bad. I got everything back together, all ready to go except for bleeding the clutch. According to the directions, it looks pretty simple. Says to pump clutch 15-20 times, then open SC bleed screw to allow any air to escape. If clutch is still soft, repeat until correct. So, that's what we did. Clutch never even began to feel right. I pushed in the clutch pedal, but the pedal will not come back up on its own. The fluid in the clutch MC does not go down at all... not even 1-2mm. I checked the hydraulic coupling and it appears to be working fine. Sometimes we got fluid to come out of the slave cylinder bleed screw, but it never was a steady stream. We tried several different things in bleeding the system, but nothing made any difference. I just don't get it.. fluid should be coming thru the line. What else can I try/look for? This truck has to be back on the road this weekend.
