xploder98
- March 4, 2011
- Hemet, Ca
- 1998 Saleen xp8 #27
The plan is to build a new intake system from the MAF on. I'll be building a new air box and using 3" Polished Aluminum Pipe. From there I wanna run a 3" pipe towards the grille and next to the side of the fan shroud. With the result being a tube from the very left oval of the grille (98 Sport grille) to the air box. A hole will have to be cut next to the fan shround but there should be enough metal that it should be fine. I also plan on wrapping the tubing in InsuWrap and building a larger box without a bottom and with 2 U shaped cut outs to Slide over the nex box and tubing. This outerbox will be packed and lined with insulating material. Should make for some Ice cold air into the engine I will post pics of where I'll be cutting the hole and putting the new pipe tomorrow. Lemme know what you guys think
