over filled transmission | Ford Explorer - Ford Ranger Forums - Serious Explorations
rm787
2001 Ford Explorer Sport
I changed the transmission fluid and filter a couple of weeks back, and unfortunately over-filled it by one quart. I should have only put 4 quarts of fluid in there, but ended up filling in 5 quarts. I have the automatic transmission - 2 wheel drive.
Is there any easy way to drain out the excess without unbolting the transmission pan? I would assume that I could undo one of the trans cooler lines with a box wrench that goes to the radiator. If so, is it the bottom cooler line that inserts into the radiator on the driver's side? If that is the case, should I start the vehicle to drain the excess fluid out, or will enough excess drain out by unbolting the line without adding pressure by starting the vehicle?
thanks.
my98nnj
Boonton, New Jersey
1998 XLT
Take the top trans cooler line off the radiator, put an extension on it and point it into a quart sized container. You also need to plug the open end on the radiator or you'll have a mess on your hands. Have somebody start the truck while you monitor the level in the quart. Shut it down when it's full.
Easy, really.
lobo411
1996 Explorer 4.0 OHV
You could try pumping it out through the dipstick tube, but there may be obstructions preventing the tube from getting to the fluid.
Otherwise pump it out as my98 says, or drop the pan. Next time you drop the pan, install a drain plug.
DoraThe_Explorer
Vermont
2000 XLS
Easy, really.
That has my vote too. It would be significantly easier if you had a buddy that could help you too.
Good luck!
rm787
thanks for the suggestions.
Hoof Hearted
Berkshire, UK
97 Explorer
Had same problem, I sucked it out filler tube using a length of tubing clear best so you can see it working, attach a top of a cleaning fluid gun from any old bottle and squeeze away into a container, be patient, but its better than dropping the pan, it can be a pain to re-seal it
drdoom
VA
2005 Eddie Bauer 4.6L 4X4
^+1 suction gun in filler tube.
