I ordered it on Ebay, about $185, if I recall properly, brand new, made by Bosch, came in the still sealed German box. Keep in mind, I was damned sure that (1) the TCC was not engaging, and (2) I had a code telling me the solenoid was the cause. The clutch itself can fail, and throw a different code, so before you buy a solenoid pack, you really should investigate further, if you can.
When I took down my oil pan, there was a little pile of bronze shavings sitting in the bottom. The failed solenoid's plunger bushing, made of bronze, had crumbled to bits. I decided there might be more crap up in there, so took down the valve body also. It had a pile of bronze on top of it, not visible until taken down. To be safe, I cleaned off the valve body carefully, before putting it back, and installed the new solenoid pack. For added safety, I installed an in-line fluid filter up close to the radiator, under the hood.
There is room to mess up doing this job, especially if you are inexperienced with automatic transmissions. I would recommend you obtain a 5R55S repair manual. If the only trouble is a non-functioning TCC, you can drive the vehicle all you want, without hurting it. IF! imp
The manual I have is Ford Motor Co. Techtran Manual, Automatic Transmission Service Group (ATSG). 18635 SW 107th. Ave., Miami, FL 33157 (305) 670 4161
https://www.atsg.us/atsg/
