peddler
- May 26, 2011
- cromer sunny norfolk
- 1999 north face
Hi I thought I fixed the transmission problem. I took it for a run today it all works fine until the engine warms up, then the overdrive light comes on and the rev's start increasing, you can select the gears ok but sounds like it is slipping and you loose drive, so drop it down from drive to to 1st or 2nd to gain speed and switch back drive and it is fine. Let the engine cool down and it is fine again until it warms up. fluid levels ok? any suggestions - filters? many thanks Gary
